Flexi Tail Doesn't Fit Compression Nut
View the thread, titled "Flexi Tail Doesn't Fit Compression Nut" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi all
Fitting a new monobloc mixer tap. The flexi tails that came with the tap (see first photo) don't fit the connection (see second photo). Is there a connector / coupler that will allow the flexi tail to connect to the compression coupling? If you could provide a website link to a connector / coupling that I could buy that would be great.
The previous tap had flexi tails with different ends than the typical sort that you'd get (see third photo).
Thanks for any help 🙂
Ginette
Remove copper tails from bottom of service valves and connect flexis to valves
Hi Dave
Thanks for your reply.
Do you mean from here IMG_0259.PNG?
I'm not sure how to go about doing that?
I tried to remove nuts from front but no budging at all.
Thanks for your help.
Ginette
Yes a good spanner and pair of grips should do the job if not turn water of at mains and see you can remove from top nuts so bottom nuts can be removed onfloor
best option would be to install some male irons where the old adaptors were
http://www.NoLinkingToThis/p/male-coupler-15mm-x-mm/69358
if you have basic hand tools like dave has said above then have a go your self
but if you havent best to call a plumber in shouldn't cost that much
brass flex tail connectors from toolstation come in 1/2 and 3/8
Can fit them in isolation valves or solder em
Reply to the thread, titled "Flexi Tail Doesn't Fit Compression Nut" which is posted in UK Plumbers Forums on Plumbers Forums.
Ginette,
Ric2013,
