flexi's
View the thread, titled "flexi's" which is posted in UK Plumbers Forums on UK Plumbers Forums.
missplumb
Hi, does anyone know where i can get braided flexible hoses in 1" / 28mm. not bothered whether ends are male or female as i can make that up but not speedfit. They are to go on some suspended fan blowers. I would need 22 of them. They are the same ones as supplied with ASHP but i cant find anywhere that sells them as a seperate item.
cheers in advance
We list dozens of different SKUs for flexis but none are larger than 22mm. Will check it out on Tuesday, and come back to you.
If you type flexible hose guide into the Bss home page it comes up with a selection of different types upto 2" BSP
@ray - thanks, that would be very helpful.
@CH4 - ive been through the catalogue as you say and gave them the codes and everything. Their answer is "just cos its in the caltalogue doesnt mean we stock it in the group", they would have o order them in as a special and have a minimum order quantity.
Hi Kris, thanks for the link - have you seen the price of them!!!! £80 for a pair, i need 22, thats over £1000 inc the dreaded vat.
You should be able to get them custom made for that quantity and less than that price.
I buy hydraulic hose and fittings from these, but they will do custom made hose assemblies;
Hydraulic Hose, Industrial Hose, Metal Hose, Caterhose, Solarhose, Fittings
Or try these;
[url]http://www.metalflex.co.uk/stainless-steel-flexible-hose-assemblies/
[/URL]
Reply to the thread, titled "flexi's" which is posted in UK Plumbers Forums on Plumbers Forums.
missplumb,
tolly,
