Floplast MDPE fittings
View the thread, titled "Floplast MDPE fittings" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Riley
Subscribed
Hi all
have been asked by a builder to fit a new mains.
He he is supplying the pipe n fittings but is using floplast. I normally only use JG so am after a little advice.
Are floplast fittings demountable?? Looked everywhere but can't find a straight answer
http://m.NoLinkingToThis/p/floplast-mdpe-coupler-25-x-25mm/17684?filtered=true
cheers all
matt
Well the JG ones can be completely disassembled by just unscrewing the socket then the pipe can be removed and the fitting re-assembled. Sorry if I wasn't clear. That's how I've always understood demountable :smile:
If you're on about the white fittings 22 & 15mm no they can't. if it's the ones in the link blue mdpe , then yeah they can
Cheers Irish I thought that they would but just wanted to save looking a knob on site if I don't get the pipe in far enough or something. Just so I can start again. Thanks again
Know what you're saying , that's why I use polyplumb you can take it apart and have a look if you're not sure!
Fortunately it is just a temp solution whilst other work is carried out, I'll upgrade to something better
Reply to the thread, titled "Floplast MDPE fittings" which is posted in UK Plumbers Forums on Plumbers Forums.
Riley,
Nostrum,
