Guest viewing is limited
flow and return going into one valve?
View the thread, titled "flow and return going into one valve?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
my old collage tutor told me that you can cut a piece of 8mm and it will thread in itself because it is soft enough, true???????
trying to to remove a radiator with combined flow and return valve. Have managed to bleed the radiator but having trouble removing it due to the pipe that runs the length of the radiator? Do I simply cut the tube to remove the rad? Don't want to cut it and then have a huge leak!!
Reply to the thread, titled "flow and return going into one valve?" which is posted in UK Plumbers Forums on Plumbers Forums.
mutley racers,
Unregistered,
