Flow gauges for central heating pipe work
View the thread, titled "Flow gauges for central heating pipe work" which is posted in Central Heating Forum on UK Plumbers Forums.
I fitted a 0-2 bar pressure gauge straight after the pump and another on the return near the boiler.
Have you allowed for the static height (if any) difference between two gauges as 9 psi or 6.2M seems to be a very high system loss??
It's not clear where the second gauge is located. It sounds as if it is on the return as it enters the boiler, in which case the head loss in the boiler's heat exchanger would not be included in the 9 psi.
Edit:
It would help if we knew which boiler you had,
Reply to the thread, titled "Flow gauges for central heating pipe work" which is posted in Central Heating Forum on Plumbers Forums.
Jones82,
doitmyself,
