Flue termination distances
View the thread, titled "Flue termination distances" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi all,
I'll be soon a qualified gas meter installer...
I came across many cases where I had to complete a A.R. report due to flue termination issues, distances from flue termination (RS appliances, boilers ...) and drain pipes, vertical or horizontal. With a fanned flue should it be 150mm yes or not? It doesn't look nice to turn off a boiler only because this distance is 50 or 100mm! would you ?
first ask yourself if there is signs of heat damage etc..... then check the manufacturers istallation instructions for the boiler. You will have these anyway if your servicing the appliance.
clearances to opening are different of course. Ask those you have trained with and you can also phone gas safe tech for an opinion. if you dare!
first ask yourself if there is signs of heat damage etc... then check the manufacturers istallation instructions for the boiler. You will have these anyway if your servicing the appliance.
meter fitter
Haha. Even more important he/she reads manufacturers instructions then.
Had a customer have there fire at risked cus a meter fitter though the coals on the fire didn't look positioned very well. The customer had the instructions but it was just at risked because. Inexperience and pressure of high work load makes this type of thing more common now.
Hi all,
I came across many cases where I had to complete a A.R. report due to flue termination issues, distances from flue termination (RS appliances, boilers .) and drain pipes, vertical or horizontal. With a fanned flue should it be 150mm yes or not? It doesn't look nice to turn off a boiler only because this distance is 50 or 100mm! would you ?
Before going ANY further,you need to consult the Unsafe procedures.
https://www.User PlumbersForums.net...ituations-procedure-april-2018-amendments.pdf
Who told you a flue too close to a drainpipe is AR? When you suggest you will turn off the boiler - what, precisely, do you mean?
Reply to the thread, titled "Flue termination distances" which is posted in UK Plumbers Forums on Plumbers Forums.
Salvatore Fazia,
firemant,
