Aug 18, 2019
DIY or Homeowner
I have a newly installed toilet but the flush only pushes water around half of the toilet bowl, no water gets to the front. Is the an issue with the toilet, cistern or pressure (water pressure in house is good)? And how can I get this issue fixed?
Many thanks
Check water level in cistern make sure its at the top. Put spirit level on the pan...accross and ft to back. There are some designer pans that are not fit for purpose and are bluntly insanitary. centralheatking
Reactions: Rae2005
It must be an installation issue....
...no manufacturer or supplier would introduce into the market a pan that doesn't flush properly... everything is tested prior to release onto the market...
These are some of the things a rep said to me when we installed 4 designer pans at a property that had a flushing issue.
We ended up replacing the pans due to non flush issues
Reactions: centralheatking
