View the thread, titled "fluxing pipework and fittings prior to soldering" which is posted in Gaining Plumbing Experience on UK Plumbers Forums.
It is a bit worrying to lubricate something that you want to grip, but it's a double edged sword. If its not pushed fully home, then chances are it's gonna pop off.
I've used a fair amount of plastic, but it still scares the hell out of me!! I feel more comfortable when using it on gravity pressure that mains. My favoured brand is Poly Plumb. You can dismantle a joint and check it's home if you are concerned.
Copper is still king though.
a mate of mine had a poly plumb fitting go on the mains, and it flooded the whole of the downstairs lifting parquet flooring and all sorts of damage, he took it apart to have a look and saw it was pushed in properly, the teeth on the grab ring had flattened and not gripping the plastic. public liability insurance and poly plumb got involved, poly plumb said it was nothing to do with them as the nut had been undone. the fittings are tightened to a certain torque and the pipe work should have been air tested to 18 bar, he said he took it apart after but they wouldn't cough and didn't want to know.
They're all our buddies until the preverbial hits the fan. Then it's every man for himself. Hence why I don't put much of it in if I can help it.
I've never had one of my own joints blow and cause damage, but I'm sure it could happen.
Clean pipe with wire wool (and fitting if it is dirty)
-Flux pipe only (as said earlier you dont want to push excess flux into the fitting)
-Assemble and heat a bit
-Clean all flux off with a dry rag
-Heat and add solder
-Wipe with dry rag first then wipe with wet rag (if you wipe with wet first, solder doesn't stay shiny)
I was told/read somewhere not to twist pipe as it can wipe flux off parts of the inside of the fitting.
Reply to the thread, titled "fluxing pipework and fittings prior to soldering" which is posted in Gaining Plumbing Experience on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
Start date
Last reply date
atty17,
borntofly75,
