R
Rogerp
I have a fortic tank where the over flow is dripping.
When I looked in the top part which I expected to be cold it was full of hot water and the ball cock had started dripping and over flowing.
Could the problem be a faulty thermostat? and could the hot water have caused the ball cock to fail.
Is it easy to change both? I am an electritian so the power bit is not a problem, just not come across this bioler before.
I plan to change the thermostate, drain the tank and change the ball cock.😕
Thanks for any help you can give.
Cheers
Roger
Cheers
Roger
