Fridge filter connection adapter
View the thread, titled "Fridge filter connection adapter" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
I would like to connect up water supply to fridge.
Behind the fridge there is 15mm isolation valve installed however filter connector has got bigger size.
I assume I need some kind of adaptor from smaller to larger size.
Could someone advise what exactly do I need please?
Or screw on something like this (looks like it might need a washer!)
or screwfix version needing ptfe tape when you screw it on existing fitting
https://www.NoLinkingToThis/p/flomasta-bush-3-4-x-1-2-/98427
Reply to the thread, titled "Fridge filter connection adapter" which is posted in DIY Plumbing Advice on Plumbers Forums.
rafal_22,
Basher,
