8 yr old Potterton Suprima 80L system boiler feeding indirect vented system via mid-position port valve.
Boiler fires up for 2-5 mins then clicks off. Goes on indefinetly. Red light never flashes. Green light is on but flashing.
Problem has been occuring for several years and getting very steadily worse. Many different engineers have had a go at sorting it, none successfully - despite their reports.
Here are some:
1) "Pcb faulty. Parts required: Pcb upgrade kit. Job Report: PCB Fitted + Tested + All Working"
2) "Intermittent fault with boiler staying alight. Boiler Not staying on long enough to heat hot water. Parts required: thermistor" Fit new thermister + Tested Ok and customer to monitor"
3) "Adjusted by-pass + balancing valves + tested. Possible scale or blockage in cylinder coil. 450 x 1050 indirect."
At the moment it has never been worse. It took 8 hrs earlier to make cylinder luke warm.
It was serviced a month ago and the guy said there was nothing wrong it and left.
I asked about this on this forum 11 months ago. Puddle said it sounded like an "air pressure switch problem or flue problem." WHPES mentioned that "the controllers on the Suprima boilers are a load of pants and always screwing up."
She'll be calling in another engineer to have a look shortly who will no doubt suggest yet another unique problem at fault which will be 'fixed' to no avail.
I'm wondering why everybody diagnoses a separate problem. Is boiler fault diagnosis really that close to guesswork?
Any suggestions of things she could say to the next person who has a look to increase her chances of success?
Here are some:
