Gas Engineer Software
View the thread, titled "Gas Engineer Software" which is posted in Gas Engineers Forum on UK Plumbers Forums.
Zippymark
Hi, i'm looking for some gas engineer software primarily to produce gas certs on, i was previously using one called Gas App UK, which was ok enough, but they've switched to a paid subscription model last week without warning , and looking at a few of the others it's probably not the best one if i have to pay. If i'm paying i want it to also be able to handle a bit more.
I'm currently giving Gas Engineer Software a tiral, just wondering if you guys recommend one?
I use gas checker most have free trials so my recommendation is to have a play about and see what you like
Tried joblogic out? Not sure if they did certs on there though.
Strangely I jse what has turned out to be the title of your post !!...Gas Engineer Software. It does what I expected. nI haven' t used any others so can't compare.
Just to update on this- i went for Gas Engineer Software and have found it pretty spot-on for certs, which is what i've initially used it for. I'm going to start using it for invoicing too, and quotes, it looks quite easy to turn a quote into an invoice once you've actually done the job.
I'm having a little play around regards using it as a calendar/planner too, and i'm finding it quite 'clunky' to be honest. I'll trial it like this for a bit, but have found quite a few bits annoying already, in that it's not that customisable. You can book for someone to show you through all the features, i think i might do that soon to make sure i'm using it to its full potential, I can report back after that if that's of interest to anyone?
I'm really looking for something that's good enough to basically fully digitalise my system, moving away from a paper diary and notebook, with automations etc. I'm not convinced this is that just yet, but we'll see.
Reply to the thread, titled "Gas Engineer Software" which is posted in Gas Engineers Forum on Plumbers Forums.
Zippymark,
Zippymark,
