View the thread, titled "gas experience portfolio" which is posted in Gaining Plumbing Experience on UK Plumbers Forums.
J
jase158
does this sound ok, cant find my old post but I have been redoing my portfolio and here it is
for boiler installs and services:
Visual checks = fine
Let by test = fine
Tightness test = fine
Working pressure = 0.8mb drop = fine, Gas rate-within MI spec.
spillagetest – fine, flue check – fine (no signs of distress),
Flue within minimum distances fromopening/ obstruction – fine
Bonding on meter, all fittings ok andpipe sealed in the wall, flame picture – fine, appliance seal- fine
Initial tightnesstest
Let by test pressure........10mb...... Pressure rise......0.................. Pass/Fail........Pass.......................
Stabilisation pressure....20mb........... Stabilisation time...1 mins..............
Allowable Pressure drop for pipe work............0mb......................in2 mins
Static pressure at meter...........23mb.....................
Allowable Pressure drop with appliances connected....4mb..............
Test pressure...20mb............ Test time......2 mins............ Pass/Fail
Give reasons for pass or fail.
All working fine, no leaks
then for the techincal details:
Working pressure at meter.......20mb...................
Working pressure at appliance.....19.2mb..............
Burner pressure…………………………15mb………
Flue gasanalyser readings
CO2................2.4.........................
CO...................25.........................
CO/CO2Ratio..........0.0010.........
Gas ratecalculation
Meter start...892.974...........................................
Meter Finish....893.061........................................
Actual Gas rate per hr....2.62m3..........................
M/I gas rate per hr.....2.6m3 p/h..........................
That's only one open flue isn't it? This is room sealed ?? To be honest I'm not sure what that is?? Will look into that??
Also have pipe sizing chart on the installs,
There's a lot of duplication in there and it looks very untidy to me.
I would be looking for something along the lines of :-
BOILER INSTALLATION AND SERVICE RECORD.
Make and model of boiler
Visual condition of boiler Pass/Fail
Notes.
Visual Condition of pipework Pass/Fail
Notes.
Condition of meter Pass/fail
Notes.
Main equipotential bonding Pass/Fail
Notes.
Let By Test Test Pressure mb Pass/Fail
Notes.
etc. and in the notes state why the appliance has passed or failed that particular test and possibly the method of testing where necessary.
You need to make it easy for the assessor to pass your portfolio and see that you understand what you have been doing.
I said no flue flow, BECAUSE you had done spillage, they go together, yes on open flued only, but you started it haha
Get a copy of a Landlords Safety Check and an installation checklist (benchmark etc) this will give you an idea of what you should be doing
Where's best place to get these kirk? In the process of doing my write ups Ashwell so anything that may help is a bonus tbh
Reply to the thread, titled "gas experience portfolio" which is posted in Gaining Plumbing Experience on Plumbers Forums.
