View the thread, titled "Gas fire , chimney liner query. Minimum 125mm/5” ?" which is posted in Gas Engineers Forum on UK Plumbers Forums.
View attachment 37204 I personally would be happy using a 5” pipe as from what I’ve read. But I can’t do the work.
You would be wrong.
Is the chimney breast built in block/bricks, or timber?
Tell the owner to contact gas safe. The fires must be notified, and the flue comes under gas work. Use the GS find an installer to check his registration or ask GS.
A registered fire guys should not be asking "lots of people". Flue if that type and size is horrendously expensive (and it will be insulated) - it probably would have been cheaper to build a proper chimney. Assuming, of course, that it has been procured legitimately.
- Direct Flues
Furthermore, only a nutter these days would fit a basket fire. As has been pointed out, they are pretty much decorative only. With a correct ventilator, they can actually have a NEGATIVE efficiency. The 6Kw is never going to heat a decent sized room, so central heating will be on. The fire heats up the chimney, massively increasing the air changes in the room, which will suck out the warm air heated by the rads.
This will not end well.
Reply to the thread, titled "Gas fire , chimney liner query. Minimum 125mm/5” ?" which is posted in Gas Engineers Forum on Plumbers Forums.
Thread starter
Joined
Heating Engineer (Has GSR)
Thread Information
Title
Prefix
N/A
Forum
Gas Engineers Forum
Start date
Last reply date
Thread Tags
Toby emery,
Andy Diffley,
