View the thread, titled "Gas fire opening unusual" which is posted in Gas Engineers Forum on UK Plumbers Forums.
Hope all is going well for the son reg man. What merchant do you use around here?
Thanks Neily. Son doing just fine, 6 months in with current major company and learning fast. I don't use any merchants as practicing retirement. But have dealt with Spec flues on an educational level.
last one i saw similar to that was knocking the custard out every evening, so ripped out the liner, popped on a pot and sealed the holes in the opening and it worked a treat thereafter.
the fire was builder installed but no name forthcoming so no point in riddoring it.
So the gas pipe needs protecting from corrosion (it's in a chimney) and a clip wouldn't kill any one. The liner and closer plate are ID as they are not the correct flue for the appliance . Also as over 15years old they should have been removed and a new one installed if required. Also pot change and ventilation.
Gather should only be used with a new liner. And unless fire is a direct connection to liner you need a gather. IMHO
You say no tape or seals dg and was thinking today about how much we use flue silicone nowadays it seems like it was only 5 minutes ago that plumbs started selling it.
Thankfully I don't install that much these days! Too many regulations to adhere too!! lol ... tell you what does my nut in! Closureplates stuck back with silicon !!!! WHY??? Grrrrrr....!!
Reply to the thread, titled "Gas fire opening unusual" which is posted in Gas Engineers Forum on Plumbers Forums.
