View the thread, titled "gas pipe/gas meter to fuseboard?" which is posted in Gas Engineers Forum on UK Plumbers Forums.
Scott_D
Subscribed
Fitting a boiler and the gas meter and outlet gas pipe are less than 150mm from the fuseboard.
Is this NCS?
Depends how close if it’s like 140 yes ncs if closer than 50mm would ar it but leave on but if I had a piece of hardie backer board on the van easier to sort it there and then
Its pretty close
Fuse board and smart meter are new
Thought it was 150mm for switch gear, is this not switch gear?
high voltage so would class it as main head eg 100amp fuse etc or meter tails
the consumer unit is metal so there should be any arc or transmission to the gas pipe from the board
Anything from the sparkie who changed the board recently within the last year ?
Reply to the thread, titled "gas pipe/gas meter to fuseboard?" which is posted in Gas Engineers Forum on Electricians Forums.
