View the thread, titled "gas pipe sizing" which is posted in Gas Engineers Forum on UK Plumbers Forums.
is the layout letters correct for the a-b and so on? and the size of pipe that is required for the amount of gas provide for each appliance. if its wrong I'm never going to get it.
at a rough look your off how many elbows for the sections of pipe?
esp for a load of about 56kw
think this will help you more bud
[DLMURL]http://copperplumbing.org.uk/sites/default/files/content_attachments/domestic-gas-planning-and-sizing_0.pdf[/DLMURL]
and give us 10 will work it out
i assumed from d-e 8.7 m3 of gas required to feed appliance f, appliance h and appliance j. all added to 4.7m3 of gas.
thank you. shaun has put me into the right direction so hopefully reading this is the proper way of understanding it.
when you do gas pipe sizing does everyone do this table to work out the size of pipe?
ive got a mears calcs but if i have to back to the books
A - B 5.7m3 2m : 2m , 1.5m = 3.5m, 35mm
B - C 1.0m3 1m : 1m , 0.0m = 1.0m, 15mm
B - D 4.7m3 4m : 4m , 0.5m = 4.5m, 35mm
D - E 4.7m3 2m : 2m , 0.5m = 2.5m, 35mm (will be ok in 28mm)
E - F 1.0m3 1m : 1m , 0.0m = 1.0m, 15mm
E - G 3.7m3 2m : 2m , 0.5m = 2.5m, 28mm
G - H 1.0m3 2m : 2m , 0.0m = 2.0m, 15mm
G - J 3.2m3 5m : 5m , 0.0m = 5.0m, 28mm
not 1000% as all ive got at home is a ft3h mears calc 😀
its down too you mate.ill do more and let you see.
would it be good practice to have the actual pressure loss at 0.5 instead of being close at 1.0.?
in theory yes but then you start going big for example 22mm for a gas fire (7kw) etc
but depending on site conditions running 28mm to as close as you could to the boiler wouldn't hurt
most manufacturers allow 1.5mb at the gas valve test point anyway, and you will find you will have a little wiggle room as the figures arnt that accurate etc (people state different for pressure loss on elbows etc) and im sure you could get it lower by doing some formed bends
Reply to the thread, titled "gas pipe sizing" which is posted in Gas Engineers Forum on Plumbers Forums.
Thread starter
Inverness
Joined
General Plumber
Thread Information
Title
gas pipe sizing
Prefix
N/A
Forum
Gas Engineers Forum
Start date
Last reply date
Thread Tags
Inverness,
spanner,
