Guest viewing limit reached
gas rate on u16 meter
View the thread, titled "gas rate on u16 meter" which is posted in Gas Engineers Forum on UK Plumbers Forums.
R
ribtickler
hi all,
is gas rating on a u16 meter the same as on a u6?
presumably less difference between start of 2min test and end as bigger volume meter?
did a gas rate on boiler and last 3 digits on meter difference was only 9 which didnt seem right to me but all combustion readings and meter pressure difference were normal?
is there a different chart i need as the one i have is upto 6m3 and not 16m3?
1st time ive had to work on a u16 and test was on worcs 24i junior?
does this indicate a fault with gas valve?
im going back to retest tomorrow to double check
The test dial on a u16 is 5 c/ft on a u6 its 1 c/ft.Do you remember how long it took to complete 1 rev?If so ill work it out for you.
hi mate its m3 so the numbers not the dial
meter reading was 07341-430
end of test was 07341-439
That's a pretty small appliance. 0.27m3/hr about 3.08kw depending on the cv where you are.
I worked it out based on ours which is 11.4
Reply to the thread, titled "gas rate on u16 meter" which is posted in Gas Engineers Forum on Plumbers Forums.
ribtickler,
Ermintrude,
