Guest viewing limit reached
gas rating cooker
View the thread, titled "gas rating cooker" which is posted in Gas Engineers Forum on UK Plumbers Forums.
Cookers kill more people than O/F appliances? Pish!
Data badge / mi tells u output of each ring and oven. Gas rate with min 3 burners ( add up output to gas rate)
Why do you gas rate with 3 burners not max?
Using 3 burners is how you check working pressure of the meter regulator if using a cooker, any other appliance you use it on full
If u use 3 u can bp at same time as gas rate. Each burner has its own input value. U test a fire front then bbu or both at same time,?
Fair enough, if you are using 4th as well, some appliances don't have individual inputs for each ring,
On BBU, I rate boiler, then fire then both,
I fitted a Hob fired it up it looked a right treat it was bound for ukraine some how ended up here they use 16mb over there the customer service department from gorenje shouted at me and told me all gorenje hobs come with G20 UK jets . I slammed the phone down cut it off charged them and told them to contact gorenje Due to the poor cust service and a disappearing rep the hob is now a display piece Still waiting for UK Jets
Reply to the thread, titled "gas rating cooker" which is posted in Gas Engineers Forum on Plumbers Forums.
diablo13,
TFGplumbing,
