Gas Supply near Wood Stove
View the thread, titled "Gas Supply near Wood Stove" which is posted in Gas Engineers Forum on UK Plumbers Forums.
PJ.
[FONT=Verdana, Arial, Helvetica, sans-serif]Help I cannot seem to find any regs on this one, I am having a Wood burner fitted into my fireplace. The gas supply pipe to the original gas fire runs inside the concrete pad of the House straight through the center of the room and [/FONT]up to the fireplace recess, [FONT=Verdana, Arial, Helvetica, sans-serif]it is currently buried around 35 mm or so below floor level, under the proposed site of the new stove, this will be concreted back in and then a 20 mm stone hearth placed over top. How far away from the stove does the pipe in the floor need to be capped off,( it cannot be capped off at source as that's somewhere unknown in the middle of the house)., i.e. how much of the floor needs chiseling out away from the new stove. I did have a gas safe engineer cap it off when fire removed but not sure he knew anything about stoves.[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]According to Stove manufactures, The stove only requires a 12 mm constructional hearth as hearth temperatures are up to or below 100c. Apparently. Has anybody an experience or advise on this.[/FONT]
the gas pipe will need to be left capped and accessible for purging of air or you need to find where it tee's off the main pipework and cut it out there. Speak to your gas engineer, get a metal detector if needed if steel, if copper a sub scanner may be better.
I had this a couple of weeks ago, I could nt find the answer anywhere, hetas or gas safe, common sense won in the end, I pulled the floor up and took out the tee.
I think common sense approach of removing a pipe that's never going to be used in that location now is the best approach, no point in leaving it inaccessible, AW why would you need to purge an unused tail?
Its what i was taught, that if you do not disconnect a branch of pipework at the point the branch starts (which you should really try and do) then you should leave a way of purging the branch to enable normal purging proceedures.
This is what i was taught 18 or so years ago and ive never done any different. I have no idea if its written down anywhere in the regulations, but it makes perfect sense to me. 🙂
Dont recall seeing that in regs but agree does make perfect sense. Orherwise you may get a pocket of air and gas in the pipe when other work is done that you cant clear.
installation pipes must not be located anywhere where temperature are likely to reach 100 degrees c. Redundant pipes should be cut back to the nearest point of the supply. BS6891.
As you say it can't do any harm, and you are right it's best to cut back as near the tee as possible,
Hi guys this gas pipe can not be within a meter of s/fuel stove needs moving asap v dangerous , sorry for butting in
Which technical document are you basing this advice, as the gas installation pipes document (BS6891) does not specify a distance.
Come on Fat Lad, I am really interested to know which document your working from. I've trawled through the HETAS technical and the gas technical documents and can't find any quotations. May be its manufacturer instructions for a particular model of solid fuel burner/stove?
Reply to the thread, titled "Gas Supply near Wood Stove" which is posted in Gas Engineers Forum on Plumbers Forums.
PJ.,
Reg Man,
