Gas Usage
View the thread, titled "Gas Usage" which is posted in USA Plumbers Advice on UK Plumbers Forums.
U
Unregistered
Hi all,
After a boiler 'service' this year, the boiler soon stopped igniting immediately after it was switched on, and would usually take about a minute or so to fire up. For various reasons I was unable to get this fixed, so I just let the boiler take its time to ignite when I needed hot water. If anything, I used less hot water, much less often as a consequence. Could anyone tell me if this ignition problem, would cause the boiler to use up to 4 or more times the normal amount of gas?
My feeling is, that the ridiculously large bills I've had are more likely to be due to problems (all of which I won't go into here) other than the actual consumption of gas. But then I'm not an expert on how inefficient a gas boiler could possibly be, in terms of its consumption. It could be useful for me to have a few knowledgeable and independent opinions on this before I start seriously protesting to the supplier.
Many thanks for your help.
Miffed Gas User
Reply to the thread, titled "Gas Usage" which is posted in USA Plumbers Advice on Plumbers Forums.
Unregistered,
Rickster123,
