macka09
1,268
88
48
Another question lads sorry. When my colleagues alter the gas/air ratio on a combi they only use a analyser but looking through some makers instructions it's states that a manometer should also be used. I know MIs have to be followed but in this picture
What is the p in and P out? Are these the ports that the manometer would be attached to?? Really sorry for all the sh ite questions.
P is negative pressure(zero governer), so you can't use a u gauge. That's why we use the fga. The inlet gas port we use to see if there's enough gas there.
Some manu's like wircestershyite/ boosh want you to also check fan pressure, pressure drop thru heat ex. And you use your manometer measure this
