secret squirrel
Here goes (its a bit of a moan) I have just replaced a thermostatic cartridge for a shower, I had to isolate the water supply but there were two gate valves on the hot and two on the cold. The pipe work between them was quite intricate and someone had obviously spent a fair bit of time doing this work.
I can't think of a reason why this amount of gate valves were used, any logical reason? As it worked out not one of the gate valves isolated the water that successfully.
As a secondary question, I ask this with some trepidation, I can't think why I would use a gate valve when a lever valve seems to be far superior.(Not taking into account cost and presuming there is ample space)
At the risk of some abuse, is there an easier way to remove paint from copper pipe other than working up a huge sweat stuck in an airing cupboard with wire wool and sand paper? 😱
