N
nsm
This one should be relatively straightforward for someone who knows there way around these Geberit flushes....
I have attached 2 pictures - one of the system and one of the jet of water.
hxxp://1drv.ms/1qxtOz3
hxxp://1drv.ms/1ubSBxs
Can't figure out how to attach images.....
It is on the inlet valve side and as you can see there is a jet of water that does not appear when the tank is filling up
- but as soon as the tank is full - then the jet of water appears.
I have taken that section out and dismantled as much as possible. I got right to the silicon inlet valve diaphragm washer
and i had read somewhere that this may be damaged/cracked. However it is perfectly good shape. Nevertheless I gave it a good wash and replaced it.
I put it all back together and I still get the jet coming out when the tank has filled.
Any Ideas?
Thanks,
Nav
Any Ideas?
Thanks,
Nav
