Gerberit Duofix WC Frames
View the thread, titled "Gerberit Duofix WC Frames" which is posted in UK Plumbers Forums on UK Plumbers Forums.
J
Joe Clarke
Hi
I have just had a Duofix frame delivered. The unit comes with a right angle bend (90mm diameter) and a 120mm diameter Pan Connector with a rubber seal. I am assuming the Pan Connector goes into the right angle bend. Do I need to use any solvent adhesive on this joint? Also, given that the standard diameter of a toilet outflow is 100mm why don't Gerberit supply a 90 degree bend to fit directly to the pan and save an extra joint? I phoned them up and they do not have one and seemed surprised that I though they should.
Many thanks
Joe Clarke
it is in two parts because they do not know the thickness of the wall or board to be fitted in front of frame
Reply to the thread, titled "Gerberit Duofix WC Frames" which is posted in UK Plumbers Forums on Plumbers Forums.
Joe Clarke,
Hardy1,
