Glow worm 30ci F9 fault
View the thread, titled "Glow worm 30ci F9 fault" which is posted in UK Plumbers Forums on UK Plumbers Forums.
JAH HEATING
Burnt my head out this one!
Internal filling loop, Soding out when try to fill.
Fitted new one, couldn't get pressure above 0 bar f9 starts flashing.
Checked on low water pressure sensor with multi, was saying that I've got 2.5 bar of pressure in system when check white and orange wires I think it was to earth.
Drained system an took sensor out that had crap in it and refilled.
Same, f9 and 0 bar.
Now I'm not sure whether by me linking the over heat stat or pushing the manual pin in, the pressure went up then to 0.4 bar, getting somewhere.
Next thing I've got no bloody display on the boiler !! I'd switched off at fuse spur and thought it had took the board out.
Eventually got it back on after speaking with glow worm, not sure how we got it on but it come back on eventually.
Now when I try to fire boiler, it gets to ignition but literally cuts dead on the 3rd ignition attemp and goes to f9 again, doesn't attempt at any stage to light again.
I'm just seeing if anyone has had any issues similar with low water pressure sensors ?
If it's the board it's not worth me getting involved, it's cheaper for glow to fix.
I’d go with the sensor mate it senses the system pressure an also looks for slight rise in pressure when the pump kicks in (think around 0.2-0.3 of bar) never had much luck trying to clean them out.
With me linking the ohstat out, I managed to get pressure to over 1 bar but boiler wouldnt fire.
The thing that's got me concerned with board is, it went off and couldn't get back on again ? Glow worm had me disconnecting bits on board and they had me checking DC voltage at j13. I was getting like 5 - 7 DC it should of been 13 - 16 dc.
Sorry just re read properly where you said you linked OH stat out,f9 can relate to overheat or water pressure sensor failure I think depending if it’s an older style pcb. Just looked at MI’s yeh the J13 is the checking between the main pcb an user interface,I take back my previous comment does look more likely to be pcb 🙁
Ive spent that much time messing with it today that I want to sort it.
The PCB is putting me off though!
I've left it with the landlord, basically said if I fit new pressure sensor, oh stat and forgot to mention prv and everything stats working then using me works out better, glow worm would cost her.
If I have to fit a board it's cheaper using glow worm, let her decide.
i would suspect the main or user interface board fault , i would also check the sequence with the low voltage plugs disconnected one at a time also handy when you have no display as normally its the low voltage components that causes that . you should also be doing continuity checks on the harness connected to th pressure sensor and other low voltage side as well
Cheers
Im going to spend an hour on it before ordering PCB.
Reply to the thread, titled "Glow worm 30ci F9 fault" which is posted in UK Plumbers Forums on Plumbers Forums.
JAH HEATING,
JAH HEATING,
