brewster2
Hi everyone.
I have a Glow Worm 30ci that is going from 1 bar to 0.3 over night.
I have changed the PRV and the problem is still there. No water coming out of the PRV.
I fill the system to 1 Bar, central heating and hot water work fine. All turned off and go to bed. In the morning the pressure is back down to 0.3.
There are no CH system leaks and confirmed by shuting off the CH valves at the boiler and pressure still dropping although there are definitely no leaks from the boiler either.
My plumber says that it is the heat exchanger that needs changing but I cannot see why this is and have held off.
Could it be a failure of the expansion tank? If so and to save money, can I fit a separate expansion tank on the side of the boiler rather than take the boiler off the wall to replace the existing one?
Please help
Please help
