Glow Worm Ultracom 24HXI - Electrical Connections
View the thread, titled "Glow Worm Ultracom 24HXI - Electrical Connections" which is posted in UK Plumbers Forums on UK Plumbers Forums.
seftonbarn
My plumber is away on holiday so cannot be consulted. He is fitting a Glow Worm Ultracom 24HXI for me when he returns. I want to chase in the cabling to the boiler before he starts. Please can someone advise where the electrical connections connect on this boiler. Top, bottom, left, right, behind? I have looked at the instructions and it does not identify where it is?
Just be aware of the route of all the pipes going to the boiler, as these will be clipped to the wall and your cable shouldn't be anywhere near these
Or behind the boiler either, the fixing bracket will also be drilled and fixed to the wall
Thanks for the advice. I will take all of this into consideration.
it will defo tell you in the instruction pg 23
Thanks. Looking at Page 23. The text doesn't explain where the connection is. There is a diagram (9.3) which kind of looks like the connection is on the lower left had side?? Is this the case. But the digram Capture.JPG shows some sort of pipe or tube and I wouldn't expect to see one on the lower left hand side beneath the boiler??
Reply to the thread, titled "Glow Worm Ultracom 24HXI - Electrical Connections" which is posted in UK Plumbers Forums on Plumbers Forums.
seftonbarn,
ShaunCorbs,
