Hi all,
I went to a call out to fix a gas leak as British gas had capped off the meter.
I traced and repaired the leak.
Upon turning on the thermostat for central heating, nothing happend so i looked at the boiler and it had F1 and F22 come up on the display. The pressure was 2.8. After I reduced the pressure to 1.5, code F22 disappeared.
However, F1 still remains. There is gas at the gas valve. When you run the hot tap, nothing happens, pump doesn't start or anything.
Boiler turned off and on again.
Any ideas as to what it could be?
