Riley
Subscribed
Jan 14, 2013
10,833
5,025
113
Sarf Coast
Hi All
working on one of these boilers at the mo
hot water is heating up to scalding point changed cylinder stat (which was dead) no difference
am now leaning toward issue with boiler but cannot work out what.
Phial was well out of position so have moved that back in.
Can't really understand how that would affect the hot water to the degree it is though
Do any of you have any pearls of wisdom
Check out the motorised valve(s) if fully pumped.
Very likely that hot water side or valve letting by when heating called for.
A new thermostat might do it, the Phial is probably way outta range by now lol! I had a similar problem last year in the same boiler, it was gravity hot water & pumped heating. A replacement Ranco themostat did it... I noticed the customer had to keep turning the thermostat down lower & lower so that was a giveaway on mine.
only by seeing if it shuts of at different settings i would start from cold set it to a low setting run it see if it turns of then go half way see if it still turns of probably easiest to change it if its fully pumped i would as above suspect valve letting by
