Guest viewing is limited
glowworm micron 50ff
View the thread, titled "glowworm micron 50ff" which is posted in UK Plumbers Forums on UK Plumbers Forums.
C
Chris H
Fan ok, aps ok, electrode sparks, burner lights for 5 secs only and then repeats sequence untill lockout. reset led constant, burner led flashing fast. Can it only be pcb?
Any help greatly appreciated.
Check polarity on the boiler electrical supply first. There are neons on the boiler circuit board that narrow down the fault somewhat. The temperature sensors on this boiler can cause lockout. The MIs will tell you what the illuminated neons on the pcb indicate in terms of fault.
Are you a GRI?
Reply to the thread, titled "glowworm micron 50ff" which is posted in UK Plumbers Forums on Plumbers Forums.
Chris H,
southcoastboile,
