View the thread, titled "Glowworm nightmare" which is posted in UK Plumbers Forums on UK Plumbers Forums.
A
andygas
I v been out to a Glowworm 30 cxi today located in my friends flat, it is a twin flue boiler terminating outyside in a standard flue, must be a two pipe flue going into a 1 pipe flue. The boiler is giving various problems, iv changed the main pcb, the gas valve, the flow switch, the pump, pretty much new boiler already, but boiler now cominbg up with f7 fault which is down to the wiring harness being damaged.
With it being easter, good friday tomorrow, saturady only oppurtunity to get this wiring loom, if its in stock, their stuck without heating and water till tuesday at least. If i cant get this loom i was wondering if there is a boiler out there that we could put in its position as the glowworm 30 cxi twin flue has ceased production. Iv been told i could put a glowworm flexicom but that it can only have a combined flue length of 20 metres, thios flue run is 30 metres. Can any1 out ther help???????
Reply to the thread, titled "Glowworm nightmare" which is posted in UK Plumbers Forums on Plumbers Forums.
