markfxy
988
449
63
can't login on google it takes me to a gaming site, IE isn't affected but I couldn't log in until I changed my password I've run spybot, malaware and system care but they havent found any spyware also microsoft security essentials has been disabled and wont restart anyone else had this problem and how did you sort it, Its driving me round the bend any ideas would be much appreciated
I think its something on my computer some sites open ok some take me to gamestore or some other gaming site I've tried everything to get rid of this malware tried system restore but thats been turned off and wont restart:banghead:
restart in safe mode and re-run scans then remove.
also disconnect internet.
tou may also have installed a search bar too.
if you have recently downloaded and installed chrome 'which uses spyware' from a link, then it is usually a spoof version...tell me about it!!lol
I only use Chrome as Firefox kept locking up and had too many flaws.
Sounds like you've got a Trojan deep in your system if it's turning off security. Run a deep virus scan of all your files with it set on "high" and make sure that you are up to date with all security updates from Microsoft.
If all else fails, try a system restore to an earlier time before the problem started. :stooge_curly:
Uninstall google chrome, and do a System Restore to a date prior to the start of the problem, and then download Chrome again and see what happens.
It sounds like a browser hi-jack, and the problem could be tricky to resolve if the relevant code has been embedded in your operating system's registry - a System Restore might take you back to a clean record of the registry at an earlier date.
If not, and if the various cleaners don't work (Ad-Aware, Spybot, Housecall, etc) then you will need to get a security tech to look through the registry and remove the offending code. Such code is often disguised and so needs someone who is savvy in spotting it as alien and additional to the needs of the system. If essential code is removed by mistake, the system can become inoperable, so you will need to make back-ups of anything you want to keep.
Tech-Support-Forum have some good security techs - they work for free, and so there is usually a queue and a wait of 24 hours or so.
A
4K
A
K
3K
K
