M
mitchellplumber
If he was that good, You wouldn't be on here looking for answers... Your plumber would have them ;0)
So the point of this website is....If he was that good, You wouldn't be on here looking for answers... Your plumber would have them ;0)
That can mean almost anything. Control boxes, photocells & solenoids on all burners can cause intermittent trouble, but , as i have already said, check the oil pump. If it is 10 yr old, then it is very old for a Riello pump as they are mainly what goes on those burners. I often carry one in from my van with my tools, as nearly always the problem. No point you waiting till winter hits hard, get it sorted with someone who knows what they are doing.Ok sat outside for a hour today watching what the boiler is doing.
After resetting the locked out boiler,the boiler fired and ran first time for 15 mins smoothly.
Then the boiler stops and takes 5-10 mins to refire,but now it is struggling to fire.
It fires,but immediatly stops,and continues to do this 3 or 4 times,
but then fires up again, and runs for 15 mins smoothly.
It repeats this exact sequence 7 or 8 times before finally going into lock-out..
I am trying to add as much detail regarding the bloody problem a i can,i am not a engineer and the 3 previous so called engineers have also fkd it up,so you tell me who do i try next????This guy is oftec registered and fully recommendedI dont quite know what you are after all the problems that it could be have been, have already been mentioned, no one can categorically say it is anyone of those things without personally testing certain things. You cannot reliably diagnose a problem from sitting at a computer screen. There are some engineers that are extremely good and there are some that are good. I personally dont like to be beaten and I havent been yet, I would be very dissappointed if I could not get a burner going or at least reliably diagnose the fault after one or two visits if the problem is intermittent. I carry about £2000.00p of parts in my van so most parts can be tested on the same visit. Get another engineer around.
I am in north devon.As mentioned,the oil pump will be looked at next.What part of the country are you in
If dirt got into oil line then it would clog to some extent oil filter at pipe + oil filter in oil pump + fire valves & everything else. If it is a decent paper element filter ( at tank ) then hopefully it will only be dirty. The 50/70 euroflame is very likely not to start in cold weather if it hasn't been set properly. The CO2 should be set correctly. Make sure the bloke working on it knows what he is doing & uses test equipment. Also he has to be oftec qualified. Oil pumps & motor condensers are what gives trouble on RDB burners.
"Has to be oftec qualified" Certainly does not.
My uncle works maintenance for a local university. A fitter by trade.
He knows heating basics so similar knowledge as first or second year apprentice.
Anyway they sent him on an oftec course and he passed.
He could name the different components of the burner but absolutely no chance of
diagnosing simple lock out faults.
Obviously there's plenty of good guys oftec registered but also plenty of muppets.
This is why I havnt bothered because its extremely unlikely I'll learn anything.
I'll stick with the manufacturers courses for updates on building regulations and keep up to date with my G3.
know oftec though unless you guys know something I don't.
Reply to the thread, titled "Grant euroflame 50/70 oil boiler failing to fire" which is posted in Boiler Advice Forum on Plumbers Forums.
