View the thread, titled "Gravity feed hot water" which is posted in Bathroom Advice on UK Plumbers Forums.
A
abacas
I have just moved into a bungalow which had some plumbing problems.Most of these were related to leaky joints.The system is powered by a Vaillant boiler plumbed to a pressurised heating circuit and a gravity feed hotwater system which I would guess is about 15 years old.The problem I am having is very low pressure ( a dribble) on the hot water both Kitchen and bathroom (bathroom worst).The header tank has a 12 foot head. It seems that there is air in the system. I remember some years ago I had this happen and I back filled the system from a tap and it cleared the issue. Now a bit older are there any dangers in going down this route or is there an easier option?
Hi. This statment is a bit confussing "The system is powered by a Vaillant boiler plumbed to a pressurised heating circuit and a gravity feed hotwater system" However air locks can be cleared by the method you mention. But i could also be fitting dezincing or corrosion. Try the air lock exercise first. Good Luck
Reply to the thread, titled "Gravity feed hot water" which is posted in Bathroom Advice on Plumbers Forums.
