View the thread, titled "gravity hot water" which is posted in Bathroom Advice on UK Plumbers Forums.
G
GAZZA19
heating working fine on pump but cant get cylinder to heat up for hot water which is gravity
just to confirm there are 4 pipes from the boiler?
2 28mm pipes to the hot water cylinder yes?
the boiler is working no problem, what is left?
blockage or air lock on the gravity circs
no i hav`nt been to check will check tom thanks but i drained the system down to fit new rads and it filled back up because i bleed all the rads
Try bubbling the system ! Be very careful ! Remove boiler stat and listen for the air going through the circs. Replace stat hey presto !
Reply to the thread, titled "gravity hot water" which is posted in Bathroom Advice on Plumbers Forums.
