N
nigel.ring
I have a Worcester Greenstar 30CD1 conventional boiler. 7 years old. GC 41-311-71. As the full burner kicks in there is a groaning noise for about 5 seconds starting at a medium pitch then going lower.
1. Condensate trap was cleaned. No improvement.
2. Worcester advised changing the diaphragm near the fan. No improvement.
3. The CO2 levels were checked and needed adjusting. Slight improvement.
4. The water channels within the Boiler were cleaned twice with cleaning fluid. Slight improvement.
5. Now Worcester are advising trying to change the gauze on top of the heat exchanger. But this seems to be speculative which, since it would cost £160 + labour, is expensive guesswork.
Has anyone experienced a similar problem? Where does the noise come from and why? Does anyone have a solution?
Its a Worcester ! get rid of it, from what you say they don't have a clue what's wrong with it ! if you want to keep boiler get them out on a fixed price repair, then its there problem for the next 12mths.
Thanks! But I hope someone else can come up with a suggestion of a solution my plumber can have a go at!!
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - View Profile: gas man - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK or Redsaw - View Profile: REDSAW - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
