View the thread, titled "Grundfos 25-80 Pump - Magna1 versus UPS2?" which is posted in Oil and Solid Fuel Forum on UK Plumbers Forums.
Replacing boiler and will be fitting Grundfos 25-80 Pump (recommended by pump sizing calculator). Any thoughts or advice on Magna1 versus UPS2?
From what I can see the Magna1 is a large beast but space not really an issue for me, but is it actually worth it? On paper specs look quite similar.
Boiler will be Hounsfield Tuscan jetted to the full 32kW. Reason I was considering Magna1 is my load will be very variable, all the way from just DHW cylinder to full 4bed/4 bath heating + 3 single panel rads in outbuilding. I wondered (from your experiences rather than just datasheet) if Magna1 handles wide load variations better? Unvented system.
Thanks for looking.
Magna 3 with dt sensor will vary the speed to match the difference or keep it simple grundfos 25-80 or wilo 25 1-8
OK thanks for replies. All noted. Can I just throw into the mix Grundfos Alpha2 or Alpha3 25-80 especially versus UPS2? Opinions? Experiences?
Reply to the thread, titled "Grundfos 25-80 Pump - Magna1 versus UPS2?" which is posted in Oil and Solid Fuel Forum on Plumbers Forums.
Thread starter
Joined
DIY or Homeowner
Thread Information
Title
Prefix
N/A
Forum
Start date
Last reply date
Thread Tags
Tags Tags
pump
Max,
ShaunCorbs,
