View the thread, titled "Grundfos,Condensate pump wiring" which is posted in UK Plumbers Forums on UK Plumbers Forums.
AWheating
Subscribed
got to wire a grundfos conlift condensate pump. Anybody wired on before?
i know it will require a feed via spur or plug, what im unsure of is the overflow cutout. Some ive seen before you just wire the live(line) supply to the boiler in series via the pump safety float switch. Dose anybody know if this is the same for this pump?
cheers for any replys!! 🙂
I have fitted two in the past but can't remember the make?
All I know is that once the condensate reaches a certain level within the condensate pump unit, it automatically triggers the flow of the condensate.
As a last resort, you may want to read the MI's😛rrr: (OK, dat woz a jokes)
the guy that will help you out is tamz i got some of him and i messaged him and he pm the best way to do it
Don`t know which model of the conlift you have but I`ve just had a quick look on the Grundfos website and the only electrical connection shown is the 240v plug.
Google Grundfos conlift, follow your way to Grundfos website.
Sorry thats all I can tell you.
See someone beat me to it
Which boiler u fitting to ? Valliant have aux where u can connect n/o contact to and set up as cut out . If u wire to std use n/c contact and 240 in series as stated above. Is it a combi or system?
don't bother phoning them 'cos they are only going to give you minimal advice and ask if you have read the MI's
Yep only option is to use the normally closed contact for the live in series. Why such a good pump on such a pish boiler? Don't put pump under boiler cos when it leaks it will ruin pump.
cant discount or turn down work because you dislike a boiler that alot of customers ask for. I personaly like WB and fit plenty of them without issues, customer gets 7-8 year warranty, you get service work.
Was just being a tit, know the score. Just get a sick feeling when all avenues have been explored and the day of job comes and the jig cuts it's way out of box and starts making a move on my fingers.
Easiest way to wire these on a worcester if the pump is near the boiler is take the wires into the boiler. Live neutral and earth onto LS, NS and E
Brown onto your switch live with a bit terminal block and blue (marked or sleeved) onto LR.
If it also has a black wire stick that into a bit block on its own. You don't need it (unless you want to fit an alarm) but it will go live if the pump fails.
This way it just cuts the heating off if the pump fails but still allows HW.
Mark it on the MI's for sometime in the future for the hard of thinking that if the heating fails check the pump.
thanks tamz. one concern i would have is i think worcester state this boiler condenses in hot water mode?. dont know how it does or what it produces tho.
Allegedly! If it worries you spit the live feed with the cut off and it will kill the lot.
Reply to the thread, titled "Grundfos,Condensate pump wiring" which is posted in UK Plumbers Forums on Plumbers Forums.
