M
mike_s
Which would you reccomend? Not interested in Salamander as the Stuart Turners seem better quality but I have recently came across the Grundfos Watermill Amazon 3 bar shower pump. It would either be this or the Stuart Turner Monsoon universal 3 bar twin.
I need a 3 bar twin impeller negative head shower pump as the pump is going in the loft, 400mm below the cold water tank and feeding 2 showers, one drench head and one standard, 30 litr/min flow rate combined.
Hi can anyone give me some advice on a grundfos Amazon double negative pump. Really desperate to get this working before having to undo lots of work done. We've had it installed in loft and my plumber is battling to get it to work. We thought on a negative it would be ok in loft?
That's my message above asking for help .......
Welcome to the forum Bronwyn. What actual problem are you having with the pump?
PS - always better to start a new thread than reviving an old one. It's more likely to get responses...
