Grundfos water circulator not circulating
View the thread, titled "Grundfos water circulator not circulating" which is posted in Water Underfloor Heating Advice on UK Plumbers Forums.
Hi, I have a Grundfos UP15 42RUC7 circulator which doesn't appear to be working. the impeller moves freely when I spin it manually but when there is power tot he device all I hear is humming but the impeller doesn't turn even though it does not appear to be stuck. Also, oddly I can not find my model # anywhere for this Grundfos. The closest I have found is UP15-42BUC7 but you can see clearly in the picture I have attached that my model is an "R" and not a "B". Any help would be appreciated. As mentioned - power appears to be at the unit and the impeller is not turning even though I can spin it freely by hand - thanks
Nope-but wouldn’t the impeller still spin even if the capacitor was faulty with power running to the unit and you can audibly bear the unit humming?
A humming/buzzing noise is typical audible sound of a cap failed or a seized motor. The motor will spin by hand as it is with a failed cap but trying to start a single phase motor without an auxiliary winding and a cap is impossible, once rotating it would be fine but not to start.
I would try fitting a new capacitor. Pick one up from your local plumbers yard for around £10. It sounds like yours has failed and not starting the impeller. Or swap the head if you don't want to fit new parts into the existing head control box.
Reply to the thread, titled "Grundfos water circulator not circulating" which is posted in Water Underfloor Heating Advice on Plumbers Forums.
Oilers,
Darren Jackson,
