W
willrobs
High
I am working on a Halstead Ace High combi. It has developed a problem whereby after it is suplied a good amount of DHW (ie fill a bath), a minute or two later it kettles (boiling sound and foam from auto air vent).
Can someone explain the mechanism by which this boiler should prevent this happening? presumably there is a pump that sould be staying on to prevent the water in the boiler from overheating - what triggers this? Is it a stat or timer on CPU? Just want to be a bit more accurate before I start replacing bits!
Cheers
Will
Cheers
Will
