halstead best 50 fault
View the thread, titled "halstead best 50 fault" which is posted in UK Plumbers Forums on UK Plumbers Forums.
cdodds2004
have a fault on a halstead best 50
had a new fan last year and the boiler is intermitantly not firing up normally in a morning, demand is the clicks but no ignition, changed the ignition circuit board for one i had lying around and fault has re-occured, seems to happen first thing in morning than after turing spur on and off boiler operates correctly afterwards, any ideas on any thing else i can check lads?
No offense but the one you had lying around probably has the same fault ( the ignition relay) I have made temporary repairs to these boards by re soldering the relay connections until I replaced the board with a new one. There are loads of these around my way but don't carry pcb as spares as they are to expensive
yea i was thinking that, as the symptoms have pritty much always been the ignition board, is it the relay connection that normally causes them to work intermitantly? think ill get a new board and try that, as im positive thats what it is! had loads were i have fixed with new boards but i have used a few used boards taken off working boilers and have always been ok aswell, but this one has been in my garage for a while
If you separate the plastic case to see the board you should be able to see the dodgy area around the relay
Reply to the thread, titled "halstead best 50 fault" which is posted in UK Plumbers Forums on Plumbers Forums.
cdodds2004,
quality,
