T
TBServices
You can't include pro combi as they're not actually a boiler manufacturer. Just a rebadged ferrolli/vokera/ideal.
Prob just ignition or flame sensing electrodes burglered, I keep them as van stock.
turns out the condensate drain pipework was blocked, first vist pressed reset and all ran ok, as water had drained away! 2nd call back and it was booming away so flipped off the fan and burner to check insulation panels etc, no probs, then it only boomed on start up ?? so had a think, check condensate drain and it 1/4 filled a washing up bowl, so blew through pipe to clear out the bacon fm the sink trap and everything drained properly, and she started up and ran like a dream. Cant blame the boiler this time just the installer and his poor idea of condensate drains working in combination with a sink, wm AND dw AND ALL THE CRUD INVOLVED!
Anything with a Halstead badge
I find anything that is part of the Vaillant group has a mixture of the original brands bad parts and Vaillants bad parts!
icos with an LF fault code, just got a call 5 mins ago for tommorrow!
Reply to the thread, titled "has anyone out there come across a worse boiler than the ideal isar" which is posted in Boiler Advice Forum on Plumbers Forums.
