Have some level 2 plumbing questions im not 100% sure on
View the thread, titled "Have some level 2 plumbing questions im not 100% sure on" which is posted in UK Plumbers Forums on UK Plumbers Forums.
U
Unregistered
Hi I have been given test questions for my 6129 level 2 plumbing and there are some
questions I am not 100% sure on would anyone happen to know the correct answer to
these as I can not find them in the materials I have will be getting a 6129 book soon
and help be much appreciated thANKS...............................
(Q.11) Which one of the following methods of jointing copper tube should not be used
for underground service pipe connections?
(a) Type A non-manipulative compression fitting
(b) Type B manipulative compression fitting
(c) Integral solder ring capillary fitting
(d) Endfeed solder capillary fitting
(Q.12) When the cylinder cold feed and cold distributing pipe are connected to the
same cold water storage cistern the:
(a) two pipes must be connected on opposite sides of the cistern
(b) two pipes must be connected at the same height from the cistern base
(c) Cylinder cold feed pipemust be lower than the distribution pipe
(d) Cold distribution pipe must be lower than the cylinder cold feed pipe.
(Q.13) Which one of the following pipes should be connected to a cold water storage
cistern by means of a filterd connection?
(a) vent pipe
(b) Distribution pipe
(c) Cold feed pipe
(d) Overflow/Warning pipe
(Q.14) Which one of the following must not be used for making connections between
systems pipework and cold water storage cisterns?
(a) plastic jointing washers
(b) Lead free solderfittings
(c) Oil based jointing compounds
(d) Non-manipulative compression fittings
(Q.18) Major refurbishment is being carried out on a large occupied dwelling. Which
one of the following should be advised before the cold water supply to the
dwelling is taken out of service?
(a) The customer only
(b) The foreman bricklayer
(c) The foreman carpenter
(d) The customer & other trades
(Q.19) Which one of the following must be carried out prior to commencing work on
moving an instantaneous electric water heater, from over a sink to a new position?
(a) Turn of the electrical supply at the water heater, tape over the switch and
carry on with the work.
(b) Isolate the heater from the electrical supply at the consumer unit, by removing
and retaining the fuse, and check for safe isolation.
(c) Check that the electrical supply to the new heater position is of the correct
rating.
(d) Ask the customer to turn off the electrical supply and isolate the heater.
(Q.20) The cold water supply pipe at the supply stop valvemust be cut or
disconnected and blanked off
(a) to prevent dirt entering the service pipe when a system is being flushed out
(b) to prevent disinfectant entering the mains through the service pipe during
disinfection
(c) when a system is being permanently decommissioned
(d) when a soundness test is being carried out on a system
(Q.21) When a cold water system is temporarily decommissioned to permit maintenance
work, it is advisable to place a warning notice saying `do not turn on` when
(a) a WC float valve, controlled by a service valve is being maintained
(b) the cold water supply is turned off at the main stop valve to permit the
installation of a WC
(C) a cold water storage cistern float valve is being maintained by isolating
the service valve
(d) a cold distributing pipe from a storage cistern controlled by an inlet service
valve is being replaced.
(Q.23) Information regarding the maintenance requirements for a shower mixer can be
found in
(a) the manufacturer`s instructions
(b) the systems installation plan
(c) current water regulations
(d) British standard 6700
(Q.26) Ceramic discs would be required to carry out maintenance on a
(a) spherical service valve
(b) portsmouth type float valve
(c) quarter turn pillar tap
(d) screwdown bib tap
(Q.27) In which one of the following cold water components is it possible to replace the
valve seating?
(c) quater turn sink pillar tap
(d) float valve to bs 1212
(Q.29) The performance specification for a water softener can be found in the
(a) current water Regulations
(b)manufacturer`s technical information
(c) job specification for the installation
(d) system layout plans
(Q.38) A supply pipe is leaking where it enters a house in a tiled shower room. The
pipe is copper, the leak is just above floor level and the pipe in the area of the
leak is green. The most likely cause of the problem would be that the pipe
(a) is from a faulty batch
(b) has been ruptured
(c) had been corroded by cleaning materials
(d) has been corroded by air in the water
(Q.39) When a screwdown pillar tap on a sink drainer is opened, there is a high pitched
vibration or whistling noise. The probable cause is that
(a) the water pressure is set to high
(b) the packing gland is loose
(c) the tap is not set into the sink top correctly
(d) a washer is split or loose
(Q.41) Water regulations do not permit the fixing of rigid screw-in type silencer
tubes to float valves, because such devices
(a) could become blocked and prevent the cisternfrom filling
(b) can corrode and fall into the cistern causing contamination
(c) could cause backflow of water and subsequent contamination of the water supply
(d) Can cause air to be injected into the cistern contents which will cause airlocks
(Q.42) The amout of noise being caused by a float valve in a storage cistern can be
reduced by
(a) changingthe valve seating for a smaller diameter valve seating
(b) fitting a larger float
(c) fitting a longer lever arm
(d) clearing any grit or debris that has accumulated in the valve orifice
(Q.44) When renewing a cold feed and expansion cistern to an Indirect Domestic Hot Water System,
the isolating valve to the cistern must be closed, and the
(a) fuse for the hot water heating appliance from the consumer unit removed
(b) main cold water supply stop valve closed and labled `do not open`
(c) domestic hot water storage cylinder drained
(d) main cold feed cistern and pipework drained
(Q.45) before removing a section of copper pipework for maintenance purposes, all necessary
controls must be closed, appropriatesections of pipework must be drained and
(a) temporary earth continuity bonding must be applied
(b) the supply preassure to the all hot and cold pipes checked
(c) checks made that the householder has sufficent water for use during the repair
(d) the water undertaker must be notified by phone before removing the pipe
1 In a two pipe system the
a) flow and return pipework are separated
b) flow and return pipework are mixed
c) return water is at the same temperature as the flow water
d) return water temperature is higher than the flow water.
2 Which of the following systems does the statement apply to?
‘The temperature of the last radiator on the circuit will be cooler than the first radiator.’
a) Two pipe system.
b) One pipe system.
c) Two pipe reverse return system.
d) Microbore system.
3 The
[FONT=Arial,Bold][FONT=Arial,Bold]minimum [/FONT][/FONT][FONT=Arial,Bold][FONT=Arial,Bold][/FONT][/FONT]pipe size for the primary flow and return pipework from an independent solid fuel
boiler, to a hot water storage cylinder, is
a) 15 mm
b) 22 mm
c) 28 mm
d) 35 mm.
4 What is the normal size of an open vent pipe to a fully pumped heating system, in a domestic
property?
a) 10 mm.
b) 15 mm.
c) 22 mm.
d) 28 mm.
5 The connection of an open vent pipe and a cold feed pipe, can be made to a fully pumped
system using
a) an automatic air vent
b) an injector tee
c) an air separator
d) a diverter valve.
6 A zone valve in a pumped heating circuit is designed to
a) isolate the circuit when the desired temperature is reached
b) permit the system to be heated to temperatures above 100°C
c) stop the pump vibrating on its fixing mountings
d) prevent water from the flow and return pipes mixing.
6129-207 Version A
7 The main purpose of the vent pipe installed on a heating circuit is to
a) fill the system with water
b) provide hot water to the feed and expansion cistern
c) introduce air into the system
d) protect the system in the event of over-heating.
Figure 1
8 Refer to Figure 1. Which one of the following components is indicated by the British Standard
symbol shown?
a) Air Inlet Valve.
b) Draining Valve.
c) Double Check Valve Assembly.
d) Pressure Relief Valve.
Figure 2
9 Refer to Figure 2. Which one of the following components is indicated by the British Standard
symbol shown?
a) Drain off valve.
b) Air Inlet Valve.
c) Servicing Valve.
10 With reference to hot water heating, an injector tee would be used where
a) a return pipe from a gravity fed cylinder and a return pipe from a pumped heating circuit are
combined
b) a common cold feed separates to feed the hot water storage cylinder and the heating
pipework
c) a flow pipe from a cylinder and a flow pipe from a heating circuit are combined
d) the secondary open vent pipe and the primary open vent pipe are combined.
6129-207 Version A
11 A mid position diverter valve
a) provides priority circulation to the hot water circuit
b) provides priority circulation to the heating circuit
c) feeds both the hot water and heating circuits simultaneously
d) is used to discharge water from the system if it overheats.
12 When fitting thermostatic radiator valves, a general principle to follow is that
a) all radiators should be fitted with thermostatic radiator valves
b) at least one radiator should be fitted without a thermostatic radiator valve
c) only radiators on a dwelling’s first floor should be fitted with thermostatic radiator valves
d) only radiators on a dwelling’s ground floor should be fitted with thermostatic radiator valves.
13 Which one of the following can be fitted with a remote sensor?
a) Diverter valve.
b) Solenoid valve.
c) Motorised valve.
d) Thermostatic radiator valve.
14 An anti-gravity valve would be fitted in a
a) pipeline where air was being drawn into a system
b) vent pipe on a fully vented system
c) cold feed pipe to stop water backing up
d) pipeline in which unwanted circulation was occurring.
15 Which one of the following components would be strapped to a hot water storage cylinder?
a) Programmer.
b) Motorised valve.
c) Automatic air release.
d) Thermostat.
16 In an indirect system of heating and hot water, which includes a cold water storage cistern and
a feed and expansion cistern
a) the water level in the feed and expansion cistern should be below that of the cold water
storage cistern
b) the two cisterns bases should be at equal level
c) the water level in the feed and expansion cistern should be above that of the cold water
storage cistern
d) the water levels in the two cisterns should be equal.
6129-207 Version A
17 In a combined hot water and central heating system, including a feed and expansion cistern
with gravity primaries and pumped heating circuits, the
a) warning pipe to the F & E cistern may be connected to that of the cold water storage cistern
b) water level in the F & E cistern must be adjusted to 100 mm below the float valve whatever the
final level
c) water level in the feed and expansion cistern should be set to allow sufficient room for thermal
expansion
d) open vent pipe for the primary circuit may be connected into the secondary circuit.
18 The
[FONT=Arial,Bold][FONT=Arial,Bold]minimum [/FONT][/FONT][FONT=Arial,Bold][FONT=Arial,Bold][/FONT][/FONT]size of primary cold feed pipe for a hot water heating system is
a) 15 mm
b) 22 mm
c) 28 mm
d) 32 mm.
19 Before filling a central heating system for the first time, it is advisable to
a) remove all radiators and replace each with a piece of temporary piping
b) turn the pump on to assist with the filling process
c) ensure that all radiator valves are left in the closed position
d) remove the pump (accelerator) and replace with a piece of temporary piping.
20 Which one of the following assists in the removal of flux from heating systems pipework?
a) Hot flushing a system as part of the commissioning process.
b) Adding soap solution to the system after testing.
c) Setting the working system temperature above 60ºC.
d) Installing all pipes with a fall away from the drain valves.
21 Combination boilers are designed to
a) provide domestic hot water and hot water heating
b) work with two different fuels at the same time
c) provide hot water from a storage cylinder and hot water heating
d) provide hot water heating only, through any type of heat emitter.
22 Which of the following is regarded as best practice when branching a large new radiator circuit
into an existing heating circuit in cold weather?
a) Drain the system down as the first action.
b) Branch into the pipework before fitting the radiators.
c) Install the new radiators and pipework runs before branching in.
d) Install the radiators, branch into the pipework and install the new pipework.
6129-207 Version A
23 When fully draining down a heating system
a) all the air vents should be closed
b) the open vent pipe should be capped
c) the air vents should be opened
d) the radiator valves should be closed.
24 A dwelling installed with steel panel radiators controlled by thermostatic valves is being
decorated. The radiators will be removed one at a time as the heating is to be kept on during
the work. Which one of the following precautions should be taken before removing the
radiators?
a) Remove the head on the thermostatic radiator valve and secure the pressure pin with a
retaining cap.
b) Set the thermostatic radiator valve to the lowest setting.
c) Set the thermostatic radiator valve to its highest setting.
d) Open the air release on the radiator, remove the thermostatic valve and block its inlet port
temporarily.
25 Which one of the following heating components may have a replaceable gland packing?
a) Zone valve.
b) Automatic air release.
c) Thermostatic radiator valve.
d) Central heating pump.
26 A pump on a central heating system has been renewed on a number of occasions. Which one
of the following could be causing the fault?
a) The system cylinder thermostat operating at low temperature.
b) Air in the radiators.
c) No system by pass when fitted with thermostatic radiator valves.
d) Damaged cylinder coil.
27 Which one of the following could be fitted in the pipeline to prevent unwanted circulation in
heating system pipework?
a) An anti-gravity valve.
b) A diverter valve.
c) A double check-valve.
d) A three way valve.
6129-207 Version A
28 The downstairs radiators in a heating system are failing to warm up, whilst the upstairs
radiators and the hot water system are only lukewarm. This is most likely to be caused by a
faulty
a) boiler gas valve
b) pump
c) heating zone valve
d) room thermostat.
29 The safety risk to customers when carrying out rectification work on central heating systems
can be minimised by ensuring that
a) all appropriate temporary earth continuity bonding has been applied
b) the system is always fully drained for every maintenance activity
c) all plastic pipework has been correctly bonded to the incoming supply
d) all thermostatic radiator valves are at their lowest setting.
30 During maintenance procedures, in addition to turning off the electrical supply to any
electrically operated components at the consumer unit, which one of the following safety
actions should be taken as part of the safe isolation procedure?
a) Place a notice on the consumer unit advising that it should not be used.
b) Ask the customer to turn off the supply and explain that it is their responsibility.
c) Turn off the cold water supply to the heating appliance to undertake the work.
d) Lock off the MCB and provide a warning notice on the consumer unit
I'm not sure what you want here - do you want us to complete a practice paper for you?
It's all basic stuff - just refer to your notes and books. The way to learn is by attempting these questions yourself with reference to what you've learned on your course.
2 b)
3 c)
4 c)
5 a)
Hmmm - not too tricky - but how do you know my answers are correct - especially given my nickname?
I'm trying, any help with these too 🙂 thanks
1 Theconnection of an open vent pipe and a cold feed pipe, can be made to a fullypumped system using
a)an automatic air vent
b)an injector tee
c)an air separator
d) adiverter valve.
6 Azone valve in a pumped heating circuit is designed to
a)isolate the circuit when the desired temperature is reached
b)permit the system to be heated to temperatures above 100°C
c)stop the pump vibrating on its fixing mountings
d)prevent water from the flow and return pipes mixing.
10With reference to hot water heating, an injector tee would be used where
a) areturn pipe from a gravity fed cylinder and a return pipe from a pumped heatingcircuit are combined
b) acommon cold feed separates to feed the hot water storage cylinder and theheating pipework
c) aflow pipe from a cylinder and a flow pipe from a heating circuit are combined
d)the secondary open vent pipe and the primary open vent pipe are combined.
11 Amid position diverter valve
a)provides priority circulation to the hot water circuit
b)provides priority circulation to the heating circuit
c)feeds both the hot water and heating circuits simultaneously
d)is used to discharge water from the system if it overheats.
12When fitting thermostatic radiator valves, a general principle to follow isthat
a)all radiators should be fitted with thermostatic radiator valves
b)at least one radiator should be fitted without a thermostatic radiator valve
c)only radiators on a dwelling’s first floor should be fitted with thermostaticradiator valves
d)only radiators on a dwelling’s ground floor should be fitted with thermostaticradiator valves.
17In a combined hot water and central heating system, including a feed andexpansion cisternwith gravity primaries and pumped heating circuits, the
a)warning pipe to the F & E cistern may be connected to that of the cold waterstorage cistern
b)water level in the F & E cistern must be adjusted to 100 mm below the floatvalve whatever the
finallevel
c)water level in the feed and expansion cistern should be set to allow sufficientroom for thermal
expansion
d)open vent pipe for the primary circuit may be connected into the secondarycircuit.
20Which one of the following assists in the removal of flux from heating systemspipework?
a)Hot flushing a system as part of the commissioning process.
b)Adding soap solution to the system after testing.
c)Setting the working system temperature above 60ºC.
d)Installing all pipes with a fall away from the drain valves.
I agree with the others, if this is the extent of the stuff you do not know, you need to get yourself a book and revise, for us to tell you would,
1. may be wrong as even well experienced plumbers forget some things occassionally
2. take up way too much time
3. not teach you but give you the answers.
Get a book, £30 for a book is cheap compared to tools, tax, advertising, diesel, i.e. just go and get a book
Also seems like you are on cold water section, if memory serves me correct you will need a different book, cold water supply and fittings is a good one, even if you get it from library
Have you actually learned anything on your course?
This is basic, basic stuff - it needs to be in your head and second nature. Honestly, you need to answer these yourself and then seek advice (preferably from your tutors) if you can't answer.
Many thanks for the appreciation/acknowledgement for my earlier answers.
Not sure why I should bother with any more.
PS - all the answers to No12 are wrong!
If these are examples of level 2 questions, what are level 1?
The mind boggles.
Level 1 is introduction to construction, so very basic stuff. basically for 16-18 year olds to understand the very basics of plumbing, electrics, brickies, carpentry i.e.
Not sure but isnt 12 both pipes should b e the same height from bottom. like i said not sure.
just been through the questions, some haven't got pictures needed, the rest don't say how many answers. makes life a lot easier when you know how many answers, but apart from that, I am shocked at how many I was unsure about. may need to research these, there's the obvious ones, like pipe sizing, who do you inform when turning the water off, ummmm, errr i think it is the water board, lol
but things like what would you use an injector tee for? Ummm I wouldn't.
what would you use anti gravity valve for, gravity hot water. but that isnt an answer.
I've been helping him on another thread!! He's obvioulsy hopping around the forum, gleaning some info here and there!! 🙂
All of the answers are in the book(s) he should have to hand.
The trick is finding them but a. Useful exercise for later courses when sitting in an assessment centre, no help and just a. Computer counting down for company...
Hello could somebody see whether I've got any wronge. thanks
1A boiler requiring a greater waterflow rate through its heat exchanger than the heating and hot water circuitsrequire, should be fitted with
a) a pressure limiting valve
b) a flow restrictor
c) a pressure reducing valve
d)an automatic bypass valve.
2 To satisfy regulations, the controlsrequired for a fully pumped heating system (hot water
priority) using a zone valvearrangement, consists of
a) two number 2 position divertervalves, time clock, cylinder thermostat, room thermostat
b)3 port valve, programmer, room thermostat, cylinder thermostat, TRVs
c) 2 port valve, time clock, roomthermostat, cylinder thermostat, TRVs
d) 2 port valve, room thermostat,cylinder thermostat.
3 Which one of the following gasboilers overcomes the need for a cold water storage cistern, feed and expansioncistern and hot water storage vessel?
a) Back-boiler.
b) Condensing.
c)Combination.
d) Room-heater
4 If TRVs or zone valves on a systemclose, the purpose of the automatic by-pass valve is to make sure that
a) water can flow through the cylinder
b) air cannot enter the heating system
c) water cannot pump over the vent
d)water can flow through the boiler.
5 The revised Building RegulationsPart L1 require that when fitting a new oil fired heating system, the systemshould be
a) gravity hot water and pumpedheating
b)fully pumped with a boiler interlock
c) heated by combination boiler only
d) installed by CORGI registeredplumbers.
6 On a fully pumped system using a 3port mid-position valve, neither the heating nor hot water can be runindependently. The most likely cause is that the
a) cylinder thermostat is faulty
b) room thermostat is faulty
c)3 port valve is defective
d) pump is running constantly
7In an indirect system of heating andhot water, which includes a cold water storage cistern and a feed and expansioncistern
a)the water level in the feed and expansion cistern should be below that of thecold waterstorage cistern
b) the two cisterns bases should be atequal level
c) the water level in the feed andexpansion cistern should be above that of the cold water storage cistern
d) the water levels in the twocisterns should be equal.
8 Before filling a central heatingsystem for the first time, it is advisable to
a) remove all radiators and replaceeach with a piece of temporary piping
b) turn the pump on to assist with thefilling process
c) ensure that all radiator valves areleft in the closed position
d)remove the pump (accelerator) and replace with a piece of temporary piping.
22 Which of the following is regardedas best practice when branching a large new radiator circuit into an existingheating circuit in cold weather?
a)Drain the system down as the first action.
b) Branch into the pipework beforefitting the radiators.
c) Install the new radiators andpipework runs before branching in.
d) Install the radiators, branch intothe pipework and install the new pipework.
I'd say c for 22 because you're keeping the existing heating on for longer before having to break into it.
Otherwise you seem to be doing well.
Read the books! You should be embarrassed asking these questions in all honesty!
Do you want me to send you the page numbers?
Read the books the answers are in there your doing ok though for a total newbie with no experience the wording can be daunting.....
But nobody and I mean no one should be embarrassed about asking questions on this forum - that's why it's here 🙂
It's not asking questions though it's asking for answers. If you'd have highlighted the answers which you thought were correct we can see where you might be going wrong.
Hello everybody
I have completed mt C&G 6129 Basic Plumbing Studies Level 2. I only failed 1 exam!!! I really want to take my BPEC Water Regulation 1999 exam. But concered that I might fail it because I've not started 6129 Level 3 plumbing, yet! Also, could somebody send me some exam questions 407398@live.oldham.ac.uk Cheers
mohammed, water regs is really easy to do it is all open book. you are given the water regs to read through before the exam. you are then given a talk about them. the exam itself gives you the question then goes on to tell you where you will find the answer in the book (which is more like a folder actually).
I wouldn't have been able to answer this a few days ago but I had a flick through the trelour book after answering another thread on here yesterday or the day before and learned (re-learned) a thing or two.
The answer is 'd' because if a mixer shower is present you want the hot to run out before the cold to prevent scalding.
Reply to the thread, titled "Have some level 2 plumbing questions im not 100% sure on" which is posted in UK Plumbers Forums on Plumbers Forums.
Unregistered,
JCplumb,
