Deleted member 85424
Im after some advice, My Keston C36 recently blew a pipe under the floor. When the engineers came to fix this they took the boiler cove off and there was a small leak at the heat exchanger. They tightened the screw slightly and we had our hot water and heating back. After about half an hour another pipe burst. I am in the process of getting this fixed but think that this problem is not because the pipes are plastic.
We have had low pressure issues with this boiler but it appears that now the pressure is too high. Is it possible that if the expansion vessel has ruptured and the heat exchanger or blow out pipe is faulty that this could cause the build up of pressure to be that severe it could burst a pipe. On the pipe they replaced it said the plastic pipes can withstand up to 10 bars of pressure so I dont know what is going wrong!
