Heating pump recommend
View the thread, titled "Heating pump recommend" which is posted in Central Heating Forum on UK Plumbers Forums.
Hi All,
Pump gone on my parents heating system it's a Grundfos 15 60 130. New one best part of £300 is there any other makes you guys would recommend?
The Grundfos UPS3 is the recommended replacement, should be able to buy one for ~ £175 or so.
How many rads?.
You don't require a UPS3 even though you can choose a mode suitable for 8 rads.
I have 10 rads with a 6M Wilo Yonos Pico (around £120) which gives great control as the constant pressure (CP) and proportional pressure (PP) settings can be incrementally set between 0.5M and 5.5M which can be quite useful if a open vented system is installed, a 6M DAB2 might also be suitable.
It's a closed pressurised system is it ok to use one of these?
Thanks found this at Screwfix for £99
WILO YONOS PICO 25/1-6-130 GLANDLESS CIRCULATING PUMP 230V
Is this the one I need as mine is 15-60-130 and this one starts with a 25?
Thanks for the help
That's fine the130mm is the distance ebetween the flanges, same as yours, there suhould be, but just check for 2 rubber gaskets, if not buytwo and install stall using these.
Reply to the thread, titled "Heating pump recommend" which is posted in Central Heating Forum on Plumbers Forums.
Funkyboy,
John.g,
