buckley plumb
just read an article in the worcester bosch installer mag on the new part L heating regs .it said that new heating sytems now have to have the upstairs and down stairs zoned seperate even if its under150m2.anyone else read this
ant
saw a system where it uses a manifold like an under floor manifold and each rad pipes go to this and every room could be set at a different temp can see this being the norm
ant
when i worked for a company we did lots of split zones some had each floor (4 storey house ) zoned and 5 ufloor heating zones they are wired as a supper s plan quite easy to wire all the oranges /greys/ blues together and the brown fed from each floor stat. i have done a combi connected to a mega flow -used hw from combi to feed kitchen sinks then split htg flow to make s plan to feed htg and cylinder which fed bathroom.
please can you explain how.
There seems to be two ways of piping the heating in a house.
The older, traditional, way is to have a single pair of 22mm pipes which snake round the house, feeding both upstairs and downstairs, with the rads connected by 15mm drops.
The second method is to split the system into upstairs and downstairs immediately after the pump and provide a separate pair of 22mm pipes for each floor.
In some cases, e.g concrete floor downstairs, the first method may be easier as the downstairs rads can be fed from upstairs using 15mm drops down the wall.
Apart from that, the second method is preferable. The difference in the amount of pipe used is negligible.
