T
Toxic Ted
Has anyone had problems pairing Heatmiser u/floor heating wireless stats to the wiring centre?
No did you fit the little aerial to the side of the beige box?
Have you xhecked the manual overide test dip switches on the board in the beige box?
Not sure they use wifi think its basic rf unless you have a network connected receiver.
If the manifold and pump started without a call from the stats there must be another signal being received or a wiring fault.
Were the led for underfloor and boiler demand lit?
I am sure you know what your doing but you do know the other zones only switch the boiler via the motorised valve and not the underfloor control box.
Reply to the thread, titled "Heatmiser u/floor heating wireless stats." which is posted in UK Plumbers Forums on Electricians Forums.
