heatrae sadia 25l 9004010.
View the thread, titled "heatrae sadia 25l 9004010." which is posted in UK Plumbers Forums on UK Plumbers Forums.
When I turn the hot tap on the solenoid is in the closed position. As this operates then the low water level sensor opens it again. So if opening the hot tap and the solenoid is closed. It would be gravity?
If it gravity then there has to be a air vent in the cylinder to allow the level to drop to fall enough to open the solenoid valve? maybe it contains a air bubble like the megaflo and the like?
Are there HW draw offs above the cylinder or on the same level?
Maybe worth checking that for scale build up, if its restricted then the flow from any hot tap will be restricted as well except its just a pure vent pipe,, any photo or description of the unit?.
I have a upstairs "1/2" cartridge tap gravity fed from ~ 0.25M that flows 4.0LPM, so if the water level in your cylinder is, say 0.15M above the tap then you might expect ~ 3.0/3.1LPM.
Reply to the thread, titled "heatrae sadia 25l 9004010." which is posted in UK Plumbers Forums on Plumbers Forums.
Matt0029,
John.g,
